Wiper Issues
The problem is at the control module under the steering wheel. There are several contact points inside that get surface corrosion and develop high resistance. The repair involves dis-assembly and a touch of 1000 grit paper and electro grease. Unfortunately the units are riveted together and you'll have to drill those out and replace with long 10/#32 screws and bolts. First though you have to remove the wheel to get at it.
That I don't know.
