No Heat From Vents
No Heat From Vents
Hey guys I'm not getting any heat in my car and I was wondering on any ideas. My heat use to work but some times would work one day and not the other, now its just straight cold air.
1) Heater Valve
2) Heater Core (I hope not lol)
3) HVAC unit in the car
Any other ideas or easy ways to check these? Are there any fuses or relays that could potentially do this? Thanks for your help guys, I appreciate it.
1) Heater Valve
1. Put the front up on ramps and bleed the coolant as per directions
2. Check fuse 17 - if its popped, no vacuum to the heater valve
3. Have someone move the heater **** and watch for movement
4. Still no heat, now you have problems. See Clarke's
The heater clip, if broken/missing, will give you only full heat with no way to regulate it.
I had the blend door servo motor go **** up on me which resulted in no heat. You may want to try swapping out the HVAC controls too.
IIRC, if the heater valve fails, it fails open. I suppose your heater core could be plugged.
