Need help. Power loss drive down the street
I was cruising in to work this morning when I hit a bump on the highway and I lost all throttle response. The engine didn't die, and as I was pulling off to the side I hit another bump and I had power again. I drove it home popped the hood to check all connections, but can't find anything loose. ![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
I did not loose any electrical, oil pressure was good, it just wouldn't get any gas.
Any thoughts?
Any thoughts?
Proprietoristicly Refined
DME/fuel pump relay would be the first thing to check.
Replace with a new unit. URO is junk. Stay with OEM Stribel
Clarks mentions that age may cause the relays to overheat and fail at times.
John
John
