Water temp gauge through the roof, warning light on. what damage could have i done?
Professional Hoon
last night i went to a car meet and somehow (i have no idea how) the hose blew a hole in itself and leaked on the way there and i noticed my water temp had risen higher then usual, the aftermarket temp gauge said ~230 F.
It was the hose that comes from the metal pipe from the headers into the firewall i think.
on the way home i stopped at a servo and topped up my water and drove it to my shop, on the way the warning light went on, my temp gauge sat at ~230 then it dropped to 150 but the warning light was still on. then my oil pressure started dropping, to around 3bar while driving, major loss of power. worst of all it was pissing down rain so i couldnt stop the car and get out (because i bought a 10L can of water from the servo incase) to full up.
That was probably a 10 min drive with the light on.. i got to the shop and shut the car off. opened the bonnet (hood) and just smelt the burnt oil. i pored some warm water back into the engine to help cool it down.
What damage have i done? i didn't see any oil leaking on the floor. no different noises except the lifters seemed slightly louder. suspecting from the cooked oil.
Is there any coolant left in the system? It sounds like a hose burst, then the engine was run too hot, baking the oil. No telling until you get an oil change done, replace the affected coolant hose and refill. While that may fix the cooling issue, I just wouldn't plan on those two items fixing it- it may just be the start of the troubleshooting. It might be interesting to know exactly how much oil comes out. Let us know.
Professional Hoon
the only reason i think it over headed was because the water was slowly leaking out of there, and possibly creating air pockets around the cooling system and having no water at the top end creating more heat and pressure.
Google engine oil analysis for your area. There should be a lab that can do it. You'll need to take an ounce or two of your old engine oil and put it into a container of some sort. We have labs around here that do it and supply the container for the sample.
Professional Hoon
i doubt it's that bad. im thinking when i drain the oil, i can examine it to see if theres any metal flakes in it (i doubt it)
As far as i know, all i'll be replacing is the oil filter and cap and rotor as that's finished. So if you could price me up on them 3 parts i'd appreciate that, if you could just sms me prices as i probably wont be able to hear you as i dropped my phone in a 20L bucket of house paint and well the speaker doesn't work well.
i'll be calling "Nine Spares" to see what they can do as they supply parts also as i bought belts from them "contitech belts"
Thanks!
Thanks!
Professional Hoon
The hose that comes out of the firewall (i think it goes in the wall) to the pipe that goes over the headers had a small hole in it and it would leak a little. I thought i fixed it by cutting the end of the hose of and re clamping it. what must of happend is the water still drained out but at a much quicker rate and the loss of water/coolant caused the block to over heat. because obviously when the water is up to temp there is water pressure and that caused the water to just jet out of the hole. it went all over the exhaust manifold but not worried about that because i can simply repair so make a new one.
i haven't noticed anything inusual for the headgasket blowing such as the water bubbling, collant/oil mixture or just a crap idle.
if i've warped the block, i know what im doing then "Cough 16v cough 3L cough cough"
Professional Hoon
car stumbles when i first turn it on... then it idles fine. only does it on the first time. if i turn it off and turn it on it's normal. it did it twice, morning when i moved it and after noon when i moved it again.
no water in the sump, no oil in the coolant..
oil is black..
will do compression test later tonight
oil is black..
