need some help guys!!
So yesterday i was driving and out of nowhere im getting no throttle response and i pull over and the car just shut off on me. I start it and it shuts off rigt away ill try to give it some gas but nothing, can a tps cause that, to start and shut off right away?
That happened to me. Fuel pump was getting weak and was only able to idle the car. Then I could only start it and it would die, then not run at all. I replaced the pump, DME relay and the fuse, problem solved.
Could be multiple other problems tho. BTW, mine is an NA, I don't have the extra parts related to the turbo.
i checked the pipes there good i always felt a little funny about the one that goes from the throttle to the intercooler because its a real tight fit and i got ot from lindsey but other than that i feel like the furl pump sounds about right
I'd probably suggest checking the AFM as per clarks-garage.
Sounds to me like you've got the dreaded groove.
Alternately, when was the last time you replaced your fuel filter? It could well be clogged and costs a lot less to replace than even getting your fuel pump bench tested.
Sounds more like a vacuum / maf issue wih it sounding crammed. Check the Maf wiring closely since you are on a aftermarket setup. Are you on just chips or do you have a piggyback of some sort. Give us a list of mods I'm on my phone and can't see sigs if you have one.
