Bushing List
Hello All,
Thank you in advance for any help. I want to replace all the old saggy rubber bushings front and rear. I noticed the extra movement a lot more since the LS1. I don't have much experience changing suspension bushings, let alone picking out a set for a 944 specifically. Mine's an '86 951. I also plan on installing Elephant Racing's bump steer kit. I've already upgraded the front ball joints to a 19mm pin. I have camber/caster plates up front, coilover conversion front with 440# springs and 29mm rear torsion bars. 295's rear tires, 255 fronts, solid mounted tranny. If there is any other relevant info need let me know!
Here's what I was thinking, I'd love to hear whether this is a workable plan.
I don't know what to do about the rear bushing of the front control arm. I can't afford the monoballs, but I can't find a PU bushing. Only a PU bushing for the front joint of the arm. Am I missing anything? I don't want delrin on the front arms because I think it would cause too much binding.
Thank you for any advice!
Regards,
Luke
- Delrin Steering Rack Bushing, Paragon Products, #: 944_RACKTACK http://www.paragon-products.com/Stee...4_racktack.htm
- Rear Trailing Arm Monoball, Lindsey Racing, 944-2221800 http://www.lindseyracing.com/LR/Pors...4-2221800.html
- Upper Torsion Tube Mount Solid Aluminum, Paragon Products, RE_MC2561 http://www.paragon-products.com/Race.../re_mc2561.htm
- Spring Plate Outer Delrin, Weltmeister, P904834 http://www.automotion.com/weltmeiste...r-porsche.html
- Spring Plate Inner Delrin, Weltmeister, P904835 http://www.automotion.com/weltmeiste...r-porsche.html
- Torsion Tube Lower Mount Delrin, Weltmeister, P904839 http://www.automotion.com/weltmeiste...r-porsche.html
- Front Front Contorl Arm PU, 944 Online, 1283537912 http://www.944online.com/cgi-bin/ASI...key_1283537912
Regards,
Luke
If this is for the street, I would not put delrin/monoballs in - the front/rear OEM caster block has been upgraded, is cheap and works well. The monoballs are OK for the track but you have to maintain them, no matter how enthusiastic the maker is - Elephant sold me a pair for the front and they were very disappointing, had to mount them with Locktite and pack them with grease as they were binding right out of the box. Although I like the idea of the technology, for street use where you mount 'em and forget 'em, they are not the answer. The steering rack bushings are overkill - I just replaced my rack this past weekend and the rubber bushings are so captive they hardly move. Besides, you will have to drop the rack to get the damn things on and while you are doing your rack just for bushings, you better send the kids to play in the neighbour's yard as your language will be 'interesting.'
Forgot to mention, the noise and driveability of a solid suspension for road use will p*ss you off quite quickly, unless you have a wide masochistic streak or are 18 years old.
Hi, thanks for the reply.
So you think that freshening up the front control arms with stock rubber bushings will keep things pretty tight? What about these PU bushings and then these stock rubber caster blocks?
Even if I wanted to I can't afford the monoballs up front anyway.
With the extra power from the LS1, and the wider rear tires it seems like the rear suspension is really flexing a lot. I've been getting some wheel hop, is that all from a lack of damping? The dampers I've got are adjustable and I plan to crank them up a bit to help the behavior. I've never attempted a burnout in the car, but I've noticed the behavior powering out of corners aggressively and letting the rear end come out a little bit. That's the reason I thought the monoballs on the rear control arms might be a good idea. Will the monoball in that position really make the ride a lot harsher? Maybe I'll drop the solid upper torsion tube mounts.
Thanks for the input on the steering rack.
Cheers,
Luke
- PU front control arm bushings, Pelican Parts, PEL-PP911941 http://www.pelicanparts.com/cgi-bin/...%2F85-91%29%20
- Stock Rubber Front Control Arm Caster Blocks, Pelican Parts, 951-341-023-01-M737 http://www.pelicanparts.com/cgi-bin/...9%2C%20Each%20
Cheers,
Luke
You might just need larger torsion bars for the rear...
If it's a street car, I'd just get new stock bushings, or, perhaps, the Weltmeister urethane ones.
