Bizarre problem - DME fried?
Old Jul 25, 2012 | 03:04 PM
Mancuso's Avatar
Mancuso
John_AZ/Ben951S: I'll check again regarding the tach bounce.
Paulyy: No chance on getting water in the DME.
Ben951S/OntarioTurbo: The fuel smell was present due to the injectors randomly firing/ticking after attempting to start the car/turning (with key still in the ON position), as the pressure was still present in the fuel lines. Good call on the question(s).
szabon: Working on finding a DME/KLR set for testing purposes.
I am definitely going back to basic troubleshooting and refraining from introducing any variables. I was just hoping for a slew of "Oh yeah, it's <insert scenario/fix here>; we've seen that hundreds of times" responses.
I am documenting the process and will share all results soon. It may have to wait until Friday as my schedule is full and I have limited time to test/troubleshoot.
Thank you all again for the replies - good bunch of folks here.
P.S. As a side note: It's important to mention here that John Vitesse is taking a short vacation (he deserves one), so rather than pester him I thought I would bring this to the group here. His patience and technical support is un-freaking-believable. So much to the point that one feels guilty for relying on him.
Old Jul 25, 2012 | 03:49 PM
OntarioTurbo's Avatar
OntarioTurbo
Yes, check for tach bounce. I have a flakey connection on one of my reference sensors that I have to wiggle periodcally to get my car to start. I see sensor replacement in the near future for me.
What about the alarm? I also experienced this one and had to jumper the alarm box as per Clarks instructions. I was not getting tach bounce then either.
Old Jul 27, 2012 | 12:55 PM
Mancuso's Avatar
Mancuso
Update: SOLVED
Good news: The chip socket on the DME had multiple cold solder joints - easily fixed!
Bad news: This resulted in damaging the Vitesse DME Chipboard and a few small components on the board.
After soldering the joints on the DME, repairing a few components, and re-installing the stock chip, the car started but ran like hell (big injectors, etc) above idle. I'm working with John Vitesse on the chipboard. Nothing like frying a pristine piece of equipment...
My suggestion to anyone that wants to replace their DME and/or KLR chip is to perform some preventative maintenance on those units.
Thanks so much to everyone that offered suggestions! This actually gave me chances to perform some preventative maintenance "while I was there".
Old Jul 27, 2012 | 02:08 PM
Mancuso's Avatar
Mancuso
Default Bizarre problem - DME Fried? - SOLVED
Re-opening thread.
Old Jul 28, 2012 | 01:51 AM
Paulyy's Avatar
Paulyy
Professional Hoon
report back when all running
Old Aug 29, 2012 | 04:31 PM
Mancuso's Avatar
Mancuso
All running!
22 PSI on e85 is quite glorious.
