Woodruff keys -- hard to find!!
Hi, I'm looking to obtain 2 or 3 woodruff keys for my balance shaft sprockets. I need at least 2 (1 for each sprocket). They are crescent-shaped...see pic.
Believe it or not, these are these are the last parts I need to finish the job! Please help if you can.
Thanks in advance. pm me.
The part # is N0127082
![](http://c767170.r70.cf2.rackcdn.com/GN0127082.jpg)
I was able to use 2 smaller woodruff keys I found at the local hardware store. They had the correct length and radius but individually they were different sizes and too thin. When I laid one on top of another, however, they matched the original key that came from the balance shaft. I had it with me to use as a guide, if you don't have one it may be a bit harder to figure out. Find the dim. of the original and see if you can create it using 2 smaller keys. Worked for me.
They cost $1.47 from Porsche, last time I bought one.
Kevin
Catellus Engineering
Kevin
