Front swaybar supports
Have any of you used or recommend those additional front swaybar mount supports? These are the ones that add an additional 45 degree brace from the front bushing support to the frame. I have to replace the stock bushings soon and saw the product on Pelican's site.
Also does anyone make or offer poly bushings for the stock swaybar sizes? Haven't seen any while shopping.
+1 on the sway supports. Just make sure that they have slots instead of holes for mounting otherwise you will curse a lot when fitting them. As for the bushings I cannot tell any difference between poly and rubber on my 30mm front bars but poly will not swell with oil, or use Delrin.
