How to tell for Rod Knock , Spun Bearing Blah Blah
Old 07-03-2012, 09:04 PM
CyCloNe!
CyCloNe!'s Avatar
Default How to tell for Rod Knock , Spun Bearing Blah Blah
Hey guys I've been getting this noise that has been bothering me for over a year and I'm trying to see if its an internal issue. It sounds like a light knock, its a consistant rythm and if I increase rpm, I don't hear it any more.
I tried removing one plug/injector wire at a time to see if it changes. Every time I remove one the car will run bad. I've always checked my oil and never have found metal shavings. I tried to narrow down the sound and if I could pin point a location sounds like cylinder 1 (listening threw a screwdriver), or just a noise from the front of the engine. From what I can tell seems to be uptop. Maybe valve tap?
I get paid friday and will buy a compression tester and see what I find but any insight is greatly valued.
Old 07-03-2012, 09:54 PM
carlege
carlege's Avatar
Usually its associated with low oil pressure
SproutSprawl LLC (02-13-2020)
Old 07-03-2012, 10:23 PM
CyCloNe!
CyCloNe!'s Avatar
Gotcha, my oil pressure is spot on..
Old 07-04-2012, 08:40 AM
944_S_TYPE
944_S_TYPE's Avatar
After extended sitting periods my "S" always had trouble with the hydraulic lifers not "pumping up" Next oil change, Before you drain the oil try running a quart of ATF in with the oil at idle for 5-10 min. Then drain. It was a dull tapping noise. sounded bad, but easily corrected. ATF is a detergent oil, and cleaned everything out.
My .02
Old 07-04-2012, 10:41 PM
JohnKoaWood
JohnKoaWood's Avatar
Cyclone... I have a compression tester and a leak down tester... But doubt either would help you...
If up top, it's a lifter ... If low its rod bearings.
Old 07-05-2012, 04:08 PM
gricec
gricec's Avatar
I would imagine if you had had rod knock for a year then you wouldn't be driving it anymore.
Old 07-05-2012, 05:19 PM
CyCloNe!
CyCloNe!'s Avatar
Ya I'm thinking its a lifter from what I can tell its not very loud but it bothers me since I'm trying to get this car up like new condition. Thanks everyone for the input.
Old 07-06-2012, 01:38 AM
txhokie4life
txhokie4life's Avatar
Rod bearings tend to quickly lead to something like this....
It's possible -- but I don't think you'd make it a year.
Can you post a video or link?
Quick Reply: How to tell for Rod Knock , Spun Bearing Blah Blah
