Muffler Exploded!!!...Thoughts
Old 06-18-2012, 04:26 PM
tbg22
tbg22's Avatar
Originally Posted by pettybird
you almost certainly flooded the car out, or were dumping HUGE amounts of gas into the exhaust. if you didn't flood out the car, check stuff like your FPR for a ruptured diaphragm.
you load a big canister full of fuel, apply some heat, and it's a bomb. it IS ungodly loud...I've seen it happen to a couple cars.
Originally Posted by renaissance.man
^ Yeah.. what he said.
I don't think I flooded the car as I was going 75mph when this happened. If it happened at start up or after difficulty starting that might make sense
Old 06-18-2012, 04:29 PM
tbg22
tbg22's Avatar
Originally Posted by fortysixandtwo
The "steel wool" is likely the sound deadening material of a glass pack muffler. It looks like a cheap muffler with rolled, not welded, seams. I bet the inside rusted out, allowing the glass pack material to clog the muffler's outlet.
The catalytic converter uses a rigid, ceramic like, material that has a grid of small holes.
This sounds right, I would certainly not put it past my PO to put a piece of Sh****t muffler on the car. I have been sorting out crap since I got the car and nothing surprises me now
Old 06-18-2012, 11:20 PM
VirginiaF1
VirginiaF1's Avatar
What year?
Model Variant? (944S, Base, S2)
Miles?
How well was it running lately?
Thanks!
Old 06-18-2012, 11:34 PM
tbg22
tbg22's Avatar
Originally Posted by VirginiaF1
What year?
Miles?
Thanks!
The car is an 86 951. Now that it happened I have been doing some research and there were definitely some classic signs of a blocked cat. It was idling rough so I recently changed all the vacuum lines were wired incorrectly and several were old and brittle so there were definitely vacuum leaks. It also had a cycling valve in place with manual boost. After that it still idled rough so I was thinking ISV.
It also had strong exhaust odor but not what I would call rotten egg which is how people describe the cat smell. So I changed the rear hatch seal and that helped some but not totally.
It also was a bit sluggish and would not go all the way to redline.
So there were definitely some signs but a lot of other things going on as well
Old 06-19-2012, 07:49 AM
curtisr
curtisr's Avatar
Whoops, wrong pic...
Old 06-19-2012, 07:54 AM
curtisr
curtisr's Avatar
Glad you're OK, dude. Hmm, I wonder if it wasn't the P-Gods trying to tell it's time to get a REAL muffler. Need inspiration? Look no further...
Old 06-19-2012, 08:34 AM
Tedro951
Tedro951's Avatar
I wouldn't give the cat credit for the rough idle.
How long has it not been making boost? Failure to achieve high RPM?
Old 06-19-2012, 10:07 AM
tbg22
tbg22's Avatar
It was actually boosting to 1.8bar but it would not rev to the redline (basically about 5k rpms was about the most it would do). Also top speed was a little over 100mph
Old 06-19-2012, 10:49 AM
pettybird
pettybird's Avatar
my blocked cat cut boost tremendously but the car would make it to redline...time to check the ignition methinks.
Old 06-19-2012, 11:46 PM
jwade944
jwade944's Avatar
This happened to me in a 924S during a race at Road Atlanta years ago. A piece of the internal muffler broke off and blocked the outlet to the muffler. It blew the top out of the muffler and punctured my gas tank. Fortunately no fire but it could have been really bad.
Quick Reply: Muffler Exploded!!!...Thoughts
