A/C compressor mounting HELP!
6th Gear
I seem to be missing some hardware for my a/c compressor. The brace is in place and tight but the compressor still wiggles a little. What holds the compressor in place. Anybody have the specifications and or schematic?
6th Gear
Two bolts? Great! I can easily see there was one and it is gone. What size bolts are they?
The exploded view I saw on the Pelican Parts website shows one bolt. Hmmm.
http://www.pelicanparts.com/944/944_parts/944_83-85.htm
But then I see now that the diagrams is for earlier 944, bummber.
Kinda funny, two weeks ago or so I realized that I had no bolts on my compressor, except the little piece of a bolt where one broke off. Had to drill it out. Not fun.
The front bolt that holds the compressor is a M10 x 50mm with a 1.25 thread pitch.
The rear bolt is a M8 x 55mm with 1.25 thread pitch.
(Length is a give or take. I believe that's the stock length, but you will most likely get either a 50mm or a 60mm bolt). Go down to Lowe's or Home Depot and grab them for under $2. Don't forget washers and lock washers to prevent it from happening again! If you're interested, the auto store should have coated bolts and washers.
6th Gear
Well bad news. . .
Pulled the tensioner brace off and found the rear ear is broken off. No idea how long but I think it was a while ago by the looks of the surface. Front bolt is sheared but the shank was intact and I was able to remove it with vise grips. Previous owner was a mechanic and looks like he put anti-seize on the bolt.
I ordered the bolts from Copperstate Nut and Bolt and they will be ready for pick up tomorrow.
I am thinking I will put the it back together and drive to chop, have a/c evacuated. I will replace the compressor myself and have the shop recharge.
Sound like a plan?
Sound like a plan?
6th Gear
I am looking at buying compressor and dryer from http://www.a-aironline.com. Anyone found the compressor and dryer cheaper and happy with parts?
