Headlights have mind of their own
Cyclone:
Ugh. That sucks. Clarks has the procedure but it looks like an affair.
Also, you could 'time it' with the switch to get them to stay down
I usually just pull the relay or a headlight fuse and they'll stay down and I've been using the fogs as headlights for the time being. Interestingly enough I haven't been pulled over and I've passed several cops camping. Tonight I'm going to work on the headlight rotary switch mentioned, if it's not that I'm considering ripping everything out lol
Well it's not the rotary switch, took it apart and cleaned it. Honestly the motor looks rather new especially in the inside, didn't have any build up on it like at all. I assume it might be the light switch then? I have constant power at the plug.
I just ordered from Lart da King of Part another headlight switch so if this doesn't fix it then I dunno... Maybe I'll light it on fire!
Well note to self so far it's not a relay, the motor rotary switch nor a headlight **** switch... I'm going to look at the wires and then check the motor where the relay plugs in, I see some rust or something, hopefully just a contact issue there.
Cycling the switch to off again at the right time. For me it was the white relay on the headlight motor. Same exact symptom
