Turbo is toast. which hoses to replace ???
#33
It is out a few mm when spun up
He said normally its just few thou
He said he could maybe try and balance it but I said just replace it
Heat droop is where heat has made veins of impeller bend in slightly apparently
#34
Professional Hoon
wow i had no idea. maybe that caused my boost issue.. i thought it was something as simple as poor fuel quality or an exhaust leak somewhere after i pulled the turbo out.
i guess you could ask Patrick if he has one laying around. or even find a k27/8 and get that made into a 27/6
actually no, don't to the k27/6 since you'll need a new chip set.
