WTB: 924s / Early 944 M030 spring perches
Spring perch part number is 937.343.525.01
Just looking for a pair those, although Lart has a US passenger side strut on eBay, so if someone has a left side strut assembly I'd be keen on that too.
My aim is to build a height adjustable setup for the front that looks stock.
mo30 parts
Hello I have a couple sets and spare parts from some turbo S cars as well as other turbo cars that were to far gone to rebuild . if you need anything or better pictures pm me . Thanks Dp951
Are you absolutely certain that's the correct factory part number? I shot a note over to Sunset Porsche and they don't have that number in their system. Sonnen Porsche doesn't show that PN online either.
Porsche 944 MO30 parts Dp951
Hello the picks of the oem mo30 struts and the adj. collars (rebuildible cores)
The yellow springs pictured are aftermarket , I wouldn't use this kind ( they tend to split ) , another option is to cut off your stock perch and weld rings on the housing so that the mo30 collars can sit on top , fairly easy process. shown are the stock springs and some progressive ones .
Feel free to pm or ring me if any of this will help, I have 20 years worth of this stuff.
Here's the close up of the perch part number from Lart's auction. Also all the parts laid out next to each other. It might not be the case, but it looks like the spring is a wider size than the 951 m030?
What I want out of this is a factory-look adjustable setup for rebuildable early struts. I can modify the struts on my car by removing the stock perch and adding the coilover piece if it fits. The last puzzle piece is the spring size and correspondingly the top mount.
I don't think these 924s/early 944 parts come up that often, but maybe someone has a set of the collars/perches gathering dust?
You'd be helping a great deal - parts are scarce in NZ, so a friendly 'lister is my best shot at the moment...
