Center of gravity relative to lift points?
Does anybody happen to know the center of gravity (front to back) relative to the lift points?
I am cutting my slab to sink my BendPak MD-6XP mid rise scissor lift below grade and I want to be sure I can get the center of gravity as centered as I can on the lift, so determining where to cut.
Many thanks.
Many thanks.
Today I got
My Custom Title
My Custom Title
The center of gravity is the point under the little diamond shaped dents under each door. If you jack the car from that point (the best jack point anyway), the front and rear will raise together
![](http://i1070.photobucket.com/albums/u491/gtroth/f8da3e54.jpg)
Not jacking. Lifting from the proper lift points. When I do that I want the center of gravity of the car to be centered on the lift. And i want the car not to interfere with the garage door or take up too much space in the shop in back. And of course must simultaneously work for the Carrera. Once I cut my slab, the lift wont be moving so i want to get it as right as I can.
If you fellas are sure the diamond is at the actual center of gravity then the diamond gets centered on the lift and the arms reach for the lift points.
Are we sure?
look along the bottom of the car, behind the front wheels and in front of the rear wheels, there are supports that have holes in them(for the factory jack) they are good lift points if you can get the lift to match up with them you'll be set.
Lift from the chassis reinforcement just in front of the rear tyres and the chassis rail at the front.
Denting/deformation of the chassis rail is normal.
Add to that I am considering front in and back in orientations, and all this for two very different cars and you can see why it's complicated. And the lift won't move once it's below grade.
I'll never hit all the constraints perfectly of course. Just looking to get the best balance.
Cheers.
Should be no issue placing the lift for perfect centering of 944S CG:
![](http://i1070.photobucket.com/albums/u491/gtroth/93fc9ca9.jpg)
![](http://i1070.photobucket.com/albums/u491/gtroth/bfb202b9.jpg)
What's tricky, and what will drive placement is the 993:
https://rennlist.com/forums/993-foru...ml#post9469197
Here's where I ended up - 52" in from the garage door. I chickened out just before the pour and added 2" to my 6" gaurd band (margin from door to the cars). Better to loose some shop space in the back than not be able to close the door with the cars up:
![](http://i1070.photobucket.com/albums/u491/gtroth/db813427.jpg)
![](http://i1070.photobucket.com/albums/u491/gtroth/50fab10f.jpg)
More build pics over on the 993 forum if interested:
lift w/ 993
lift w/ 993
