Quick oil pressure sending unit and gauge behavior question
Spell Checker
OK, got my car all assembled and wanted to confirm that it was making oil pressure just by cranking. I can't even remember if the gauge will show such limited pressure. How should the oil pressure behave when simply cranking the car? I will do some searching, but since I want to try and start the car in the AM, thought I would ask too.
Separately, I remember that if you wire it backwards it will always show high pressure. My tach bounces, so I think I am go for launch when I wire everything up tomorrow AM.
Spell Checker
OK, it seems the correct behavior is when the ignition key is on, the gauge is supposed to read 0 then register oil pressure from there. I think I have the wires backwards or grounded, so I will check that tomorrow AM.
Right, it shows zero and then climbs as the pressure builds. When I fired mine up for the first time, I pulled the plugs when I first cranked it, and the pressure built fairly quickly.
Spell Checker
Thanks so much Tom. You pulled the plugs because you didn't want the engine to build compression without fuel or something? I have the fuel fuse pulled and the injectors are not connected to the harness (and there is no fuel in the tank as I drained it). I guess I don't see why that would matter, but would love to be educated. I think the wires are backwards, but if I can't get it to work, I will have to assume it builds oil pressure and just go for starting the engine given my need to get it started. Since the oil pump is mechcanical and I remember the pressure being fine, I think that is a safe bet.
Spell Checker
I will try that, but if the mechanical oil pump is my problem **** it as I don't have time to fiddle with it as it is going to storage. I'll check the wires and see where I get tomorrow. Thanks again for the advice. With any luck this thing runs, I put new belts on there, and I drive it around a bit. Worst case scenario, it goes to storage and I deal with it when I get back from Japan and buy a house in maryland.
If you're looking for a starter, it's worth considering this:
http://garage.ideola.com/prod-HiTorque.html
(Rennlist sponsor)
(Rennlist sponsor)
Spell Checker
(Rennlist sponsor)
(Rennlist sponsor)
Sorry about that. I think you can get rebuilds at your local autoparts store if you want. Maybe not the best quality though... Did you get the oil guage sorted?
It's almost a direct bolt in.
You may need to adjust the mounting to the bracket, but it's easy to do.
The other change is swapping a the ring for the starter "activator" to a different plug. Again, very easy to do (just crimp on a new end).
Spell Checker
Tom, gauge seems sorted. I am wanting to do it right, so a known good vendor it is. Also, I need to schedule with my buddy because I don't go under the car by myself these days.
Spell Checker
Hmmm, I honestly don't have the energy for anything other than direct. Ima get the reman unit. Thanks for the heads up. Also, it is unclear how they ship and I would like to do it some day this week.
Spell Checker
Quick update for bros that GAF. I used a bosch reman from zims. Unit was very nice, and worked just fine when I turned it over to check oil pressure. Was able to get the car started and idled for a bit, but I shut it off because I want to install my new oil sender unit first. Will see if I can get the car to idle again tomorrow. Engine went up to just a little over 1k and sounded exactly as I expected.
