weltmeister sway bar installation instructions
2nd Gear
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
anybody have instructions for installing STAGE 2 bars on my 1985.5 944??????????????????????
i'm expecting them in a couple days ......i'd welcome any help................thanks
rushfan944![order](https://rennlist.com/forums/graemlins/order.gif)
ilook4warduptop@yahoo.com TOM
rushfan944
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
I replaced my oem with weltmeister, but the front one walks side to side, causing bushing wear & clearance issues. Tried different fixes over the years, but eventually went back to oem M030. At least put some collars around the bar to reduce side to side walking. Weltmeister can provide another set of instructions if you ask them, assuming you're buying used.
rushfan944, here's an EXCELLENCE article on installation when the bars first came out. I noticed some design changes to the bar I recently installed.
http://thedge.info/index.php?d=rennl...eltmeisterbars
hotshu, did your weltmeister bar make a clunk/pop when it walked side to side? I've been chasing a popping sound on turn-in to right hand turns from braking. It's right at the transition moment when the bar would first get force. I've put a wrench on everything but the noise is unchanged.
You can hear the noise clearly in this vid.
Rich
Rich
Check the bushing for the control arms at the crossmember. As I stiffened up my suspension I found that that bushing began to disentigrate. If you can go to a solid mount there it is best. I used to use the plastic bushings commonly available and they failed quite frequently and would pop as they failed.
944, bar, bars, brace, front, iinstructions, install, installation, installing, porsche, strut, sway, swaybar, turbo, weltmeister
