How bad is it if a piece of the foil seal from my oil quart went into the engine?
Old 04-19-2012, 04:42 PM
Darwantae951
Darwantae951's Avatar
You would be able to fish it out with something. A whole cap would not make it into the oil pan.
Old 04-19-2012, 04:50 PM
acorad
acorad's Avatar
You are effed. Might as well just give the car to me.
Old 04-19-2012, 05:03 PM
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
this is the biggest to do about nothing—
chances are, the screen's already half clogged with 25 years of engine mud and sediment.
Old 04-20-2012, 02:49 AM
Sentinelist
Sentinelist's Avatar
Yeah, after 140k+ miles, the screen could probably use cleaning- I may have that done at the next interval next month. And the filler neck tapers at the end so a whole cap is easily fishable (as would be the whole paper seal under it) and wouldn't make it inside.
Phew...
Old 04-20-2012, 10:12 AM
sweetskillsrk
sweetskillsrk's Avatar
I've never dropped the foil seal but about a year and a half ago I took an oil sample and the first try did not at all go well. The tube that I used to draw the oil out got sheared off by the bottom of the dipstick tube so I now have about 2 feet of plastic tube in my oil pan. I'm not a fan of it being in there, but I'm not willing to open up the non-leaking oil pan just to get that out of there. So, is it a big deal? No. Again, I don't like foreign objects in my oil pan either but it's not worth it to me to open everything up just for that reason. Just wait till you do your next big maintenance to get any debris out. Although an oil change would probably work for something as small as some foil.
Old 04-20-2012, 11:48 AM
Sentinelist
Thanks, Landen- I'm due for a change very soon and may have them clean the screen and/or/if anything else possible without replacing the pan gasket yet. That'll probably be end of year. Have driven it a couple more times since and all is still normal without any strange signs.
Old 04-20-2012, 05:17 PM
Darwantae951
Originally Posted by sweetskillsrk
I've never dropped the foil seal down the filler tube, but I can tell you the PO dropped a whole cap down into the filler. It was found in the oil pan so yes they can actually make into the oil pan.
Have you ever actually had an AOS off of a block?...
I don't know how an oil cap managed to end up in your oil pan, but it sure as hell wasn't via the AOS.
You're fine. Don't worry about it. You can't even verify that it entered the AOS, so you are psyching yours elf out.
Old 04-20-2012, 08:31 PM
JohnKoaWood
JohnKoaWood's Avatar
I'm with Darwin... You're psyching yours elf out!
Old 04-20-2012, 08:38 PM
Sentinelist
Haha, I'll gladly accept that.
That's a smaller cap than I have, btw- most quarts of oil have a cap roughly 1.75" in diameter without the little fins inside.
Wow when was the last time we discussed caps and debris at this length!?
Old 04-20-2012, 09:30 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,190 Likes on 1,237 Posts
Only if they follow your advice for oil change intervals.
Old 04-21-2012, 05:36 PM
Darwantae951
I see more of the smaller caps, than the larger ones. Only the gallon jugs of oil in my garage have larger caps than that.
Old 04-22-2012, 10:35 AM
JohnKoaWood
Mobil 1 quarts have HUGE caps!
As do Elves with big heads!
Quick Reply: How bad is it if a piece of the foil seal from my oil quart went into the engine?
