12v key switched power from ignition switch?
Old 03-27-2012, 06:52 PM
RED.86.951
RED.86.951's Avatar
Default 12v key switched power from ignition switch?
what wire on the back of the ignition switch should i use for 12v key switched power?
Old 03-28-2012, 12:10 AM
n_hall
n_hall's Avatar
i don't know off the top of my head.
get a test light and start testing.
Old 03-28-2012, 12:44 AM
supes6
supes6's Avatar
If you pull up the fuse box, there is an empty connector socket labeled "A". You can plug a 1/4" disconnect onto terminal A21 to get switched +12v.
Old 03-28-2012, 01:09 AM
Butters944
Today I got
My Custom Title
Butters944's Avatar
Location: Las Cruces NM (NMSU) / Fountain Hills AZ (home)
For these things, I usually fish around the fuse box until I find somewhere to plug in... Haha
Old 03-28-2012, 11:00 AM
RED.86.951
RED.86.951's Avatar
I need a power supply that wont cut out while cranking the engine, i was simply going to tap in to the 'out power on the ignition switch and run a relay to the EMS unit. Car currently doesnt have power, hence the issue with no testing light.
Old 03-28-2012, 11:03 AM
RED.86.951
RED.86.951's Avatar
I thought about doing an 'add a fuse' in the fuel pump fuse spot in the fuse box... i just think its kind of a hack job and would rather wire it in the "right way".--- whatever that means......
Quick Reply: 12v key switched power from ignition switch?
