WTB Turbo Sway Bar F&R
Looking for front and rear sway bars that i can put on my 1987 944n/a.
Would like the 25.5mm front but if the price is right i can use the 24mm.
Need all hardware please.
Let me know what you have.....Thanks
Well i guess i should have been more specific. A fellow Rennlister offered a F&R sway bar to me for $80 plus $31 shipping. I agreed and when it arrived it didn't have the linkage i needed as well. My fault for not clarifying but he should have mentioned that he did not have any associated hardware. I think a partial refund should be in order but he never offered even after i was clear about my disappointment.
Anyway i paid $112 for a F&R sway bar set that is going to have to be duct taped to the underside of my car, unless i can find the bits. Does anyone have the hardware needed for the pair? Charlotte area? 28078?
Well the rear is 18mm a common size and the front 25.5mm. I could get the whole kit on ebay for $125 shipped. Figured id try save a couple $$$ and help out a rennlister. $112 plus all the other bits is going to cost me a lot more than $125. So not a great deal. IMO
are you completely and utterly missing the sway bars from your car? the only changes would be the bracket bushings for the front and rear, and you can get those in urethane on ebay for under $30-35. the end links in the rear, the end links up front and the metal hardware is all the same no matter the bar diameter.
You're right. I can get away with the front. So that isn't a big deal.
The rear never came with the sway bar. And i think the Camber bolt is different if your car was so equipped. And of course the drop links and brackets. I was planning on replacing bushings.
Pelican has the different bolts or they list them anyways, $21ea.
I have some brackets from my boxster that i hope will fit. If not then i will try source some on ebay. I got some rod bearings at a local race shop that i hope to replace the drop links. $10.
