turbo clutch in n/a.
Iirc different flywheel, flywheel sensors and I think bellhousing too, so no because the sensors would not be there to signal the na dme correctly.
The turbo disc is 240mm diameter (someone correct me if I'm wrong), and the NA disc is 225mm diameter. So you couldn't put just the clutch in the NA flywheel/pp.
Then if you wanted to use the whole turbo setup, you can't because the NA and turbo use a different number of teeth on the ring gear (throws off the ecu).
