Fuel leak at pressure regulator -- early car
I have a fuel leak at the hose where it connects to the pressure regulator with a screw clamp. The hose is obviously cracked from the outside. My car is an '84 which has an entirely different hose layout than the later cars.
I plan to take it to the shop to repair since I feel really uneasy doing fuel injection repairs even though I've done the water pump and timing belt. I don't have any experience doing hose repairs.
From my research in the archives, there are two methods of fixing this leak: (1) dremel or hack-saw off the fitting (?) and install a new hose with clamp, or (2) replace the entire fuel line which appears to require dropping the rear suspension ($$$). I'll probably want to replace the other line as well.
My car has 150K miles and is a bit ragged -- clear coat is peeling and has a few dents, but I plan to keep it for a while.
Assuming the shop would want to replace the entire line and won't do the easier option, is it worth it on this car? The expensive is not necessarily a problem for me, but I wonder if it makes financial/repair sense or do I find another shop who would do the second type of repair (if anyone can be found at all whom I trust)?
I guess what I'm asking is, would I look ridiculous in replacing the entire line?
Why would you Dremel off a screw clamp? Can't you turn the screw? That notwithstanding, you don't have to replace the entire fuel line. Threre's a good article on Rennbay.com about replacing just the rubber lines. Go to: porsche 944 fuel line replacement on Google.
I thought it was on the other side of the fuel line where the hose meets the hard-line, where I would have to dremel off the fitting.
Anyways, you can see that I am not confident about replacing it myself.
We have fuel line kits for both types of early cars. They use compression fittings to the hard lines and replace just the rubber sections.
http://www.rennbay.com/fuel-hose-rep...ate-p-147.html
Thanks, I saw that and asked the shop about the Rennbay kit. They just replaced a single leaking fuel line using their own solution for $100. I think they mentioned it used compression fittings and they said they'd used it many times on other cars. I will try to upload a pic when I get the car back.
