Final check of my parts list.
I'm getting ready to do a timing belt, water pump, front end seals, head gasket ect on my '89 944. I want to make sure I'm getting everything I'm going to need. I'm going to post what I think I need and links to pelican even though I may not buy it from them. Should be a fun spring break.
Timing belt, balance shaft belt and rollers.
http://www.pelicanparts.com/cgi-bin/...9%2C%20Each%20
Water pump (probably get a zims reman). What is all the stuff in this kit besides the gasket and thermostat? Also, should I replace the guide bar a nuts?
http://www.pelicanparts.com/cgi-bin/...C%20Each%20%20
Front end seals and sleeves
http://www.pelicanparts.com/cgi-bin/...Turbo%29%20%20
Oil pump drive sleeve
Oil cooler seals and going with a turbo oil cooler
Head gasket set. Hopefully I can figure out what all the gaskets go to
http://www.pelicanparts.com/cgi-bin/...38%39%29%20%20
Probably an injector reseal while I have the injectors pulled out.
While I'm not sure on the head gasket set, I was told I was pushing a little vapor during my last autocross last year. Also I want to pull off the cam town and intake maniforld to paint or pc so while I am there or close enough..... Also makes it a lot easier to do the oil cooler. Where I can get an alightment tool for oil filter housing? Anything I am missing that's TTY or one time use that will have to be replaced. I'll also be buying a set or Arnworx tools unless I can find someone local that will let me borrow those.
Is there a good write up on changing the sleeves? I have my factory service manual, and between that and clarks-garage O can probably figure it out.
