What else to check?
I am going to replace the clutch in my '83. The timing belt was done about a year ago with the water pump. The car has near 90K and I have gone thru all the paper work from PO and havent seen anything major, belts, oil...ect. I was planning on doing the following while under the car.
1. replace trans fluid
2. replace RMS
3. re-pack CV,s
4. re-pack wheel bearings F&R
5. paint calipers
6. brake job
7. SS brake lines
8. short shift kit
9. filters and oil
I would like to shorten the shifter but still keep factory ****, just to make it easier to get to radio. Still debating struts and shocks.
It is a week-end toy and stays pampered in the garage. I would like to get it to up to use as a DD, no plans on DE's or racing, occasionally a little sprited on the interstate.
SO.......what did I miss or forget about?
2. replace RMS
3. re-pack CV,s
5. paint calipers
6. brake job
7. SS brake lines
8. short shift kit
9. filters and oil
I'd also recommend going over all your suspension components.
Check the rubber on your sway bars if yours was optioned with them
Check for play in the control arms and tie rods
Check for movement on the shocks
These are all safety issues - I caught a potential failure of a tie rod before it happened by doing this.
