Brake Questions
Hello, I have a '86 944na with stock brakes. I pulled my front calipers off to paint them an noticed that the Left Front Caliper is missing a Wire Clip? When I compare the two calipers. The Right Front Caliper has a small wire retaining clip. The Left Front Caliper is missing this clip. Where can I purchase this clip? Also who sells a rebuild kit for my stock 1986 brakes?
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
www.paragon-products.com can supply you with everything needed.Calipers rebuilt kits will be front #928-351-941-00=$9.00 rear #928-352-941-00=$21.12.Unfortunetly clip/pins & brake pads retainers don't sell individualy & are expensive kit is # 944-351-952-01=$63.11 this is for both front wheels,assuming we are talking about the same thing.See pic.Maybe someone has a spare one & can could supply you with one.
iirc that clip is also part of the caliper assembly and not available separately, you need to buy another caliper for that side.
![](http://i1196.photobucket.com/albums/aa409/thomakis/b8962ae6.jpg)
