Need help with new motor mount fitment
Hey guys - I'm in the middle of replacing my motor mounts and I'm having some trouble. When installing the new mounts, does the upper outside edge fit into the cast "overhang" on the cross member, or does it just butt up against it?
If it is supposed to fit under it can anyone offer any advice to accomplish this? I haven't been able to squish the mount under there.....
Yes it goes in the slot. It doesn't appear you've dropped the crossmember at all? That's very likely necessary. Is that a spacer on the top side of the crossmember? I don't recall there being one there, but it's been a while.
Fun job, isn't it?!
Fun job, isn't it?!
Well I finally did get it together. What a pain. Used grease. Used pry bar. Struggled for a while but eventually got it together. It was just as much of a pain to line up the 2 upper bolt holes. Thanks for the help guys. Now it's on to the oil cooler housing seals....
