Wrapping a 944 with Vinyl Graphics?
Our vampire convent is in Seattle lol. in fact my cabrio should cost less than a coupe.
An alternative to a full car wrap is going with cut vinyl graphics - that's some of the stuff I do. It's a bit cheaper and easy to put on since everything's smaller.
Here are some sketches I've done for my car and others.
I've got vinyl Martini Racing graphics on my 951. They were awesome for about 18-24 months and then they started to fade and shrink. And that's with the car parked in a garage when not driven. You can buy the equipment and prep/spray a car yourself for less than getting a car completely wrapped. Applying vinyl isn't a fun job at all but it's not rocket surgery. Let me know if you want to see pics of how my car turned out/how the vinyl aged.
The Oracal vinyl I use is guaranteed for 8-10 years outdoor exposure (depending on color).
I am a graphic designer and work for a company that does vehicle graphics and wraps. About 2k should cover your costs but I am sure the price varies somewhat depending on where you are located. Where I work, we typically charge $2200-2500 to wrap a large vehicle like a truck....$1500-2000 will handle a smaller car like a cube or prius. 3m is our preferred material and what I would insist on if you wanted it to last. We have tried several other brands that are usually cheaper and they just do not install as easily. Avery and oracal are proabably the only other brands I would consider as alternatives. There are not going to be any templates for a 944 as it is just too old....most of the templates are for vehicles produced since the mid 90's on. A graphic artist should be able to design a wrap without a template using photoshop and high resolution shots of the car from side and front angles. You need to have a unit of scale (I use a ruler) in the photo so they know how to scale the final artwork. You can also make a template in illustrator or a similar program using the photos to build an outline similar to what was posted earlier. Like some mentioned...having complicated artwork flow around the edges like from the fenders to the hood can be a challenge. Usually the hood and roof are done in separate pieces from the sides so matching them up perfectly takes some time. Make sure whomever does the wrap uses a quality overlaminate on top of the film as this protects the printed vinyl somewhat from fading and minor scratches. Some companies use a liquid laminate that is like milk that is baked onto the film after printing....I would not recommend it as it provides little protection...make sure it is a film laminate. Solvent ink based printers color tends to last longer...water based is probably more environmentally friendly but durability may be compromised. Good luck!
Me and my friend did the car wrapping stuff from these guys cheap and well reliable.
