Fuel Pressure Drops Quick when parked - Options?
I will know tomorrow if the dme resolder of the injector controller area did the trick. I tried the dip stick drip test as described previously and Tue results seemed reasonable. I still have not seen how much fuel pressure one should have after an hour or two.
*edit*
Rats. Still problematic. =( lumpy/car shake still. Now the question is, is it temperature driven, or just after sitting 'overnight'. Oy.
Ben
*edit*
Ben
Sure,
It was dropping within spec, no leaks. Clarks garage has the spec. The Fuel Pressure gauge (ProSport) works great.
Running rich because I have a cam, and vacuum is 'different' than spec because of that, and the 3.0FPR is over-kill, even with the A-Tune, so back to 2.5 and it's much better. Could probably use an adjustable.
