grounds
ok so i was cleaning the grounds today on my daughters 85.5 944 and got to the second one near the left side front strut. I didn't have one there. found a couple wires not connected to anything. One was brown and one brown with a stripe. also I don't have the yellow thing in the second picture. What is it for?
Thanks in advance.
Thanks in advance.
I believe thats for the ABS System. 87 and later.
The grounds you should be most worried about: The primary one on rear of the bellhousing, the one in the battery box, and if you feel ambitious, add another in front, from the cam tower, or lift point to the forward left ground point.
