Speed Brake Bleeder Valves
WRONGLY ACCUSED!
Received 4,003 Likes
Has anyone ever used speed brake bleeder valves. While scrolling through Pelican Parts I came across these.
http://www.pelicanparts.com/catalog/...MISCLL_pg9.htm
This is the Pelican description:
These little valves are the latest innovation in bleeding your brakes! With the Speed Bleeder Valves, you can now truly make bleeding your brakes a one-person operation, fast and easy! Once installed, these valves become a permanent part of your brake system. The Speed Bleeders contain a small check valve that prevents air from entering back into the system once the old fluid exits. To bleed your brake system, simply open the valves and stomp on the brake pedal a few times. There are 2 bleeder valves and dust caps per package.
Sounds like a good idea in theory but just curious as to anyone's experience with them.
WRONGLY ACCUSED!
Thank you - Motive bleeder it is! Sounded like a good idea in theory.
