18 Inch Turbo Twist/Tire Size
I picked up a set of 18inch Twists off a 2001 Boxster S. It's the Solid Spoke 18x7.5 and 18x9 ET52. Is anyone running the 265-35-18 on 87-newer 944/951?
Thanks for the feedback
Kevin
Kevin
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
295/30/18 on 9.5 wheel, clears fine.
Doa - do you run the 225/40/18's on the front with the stock setup otherwise? I'm having clearance issues and have bent my fender since having that tire/wheel on. Looks like rolling of fenders and updated castor blocks would be the fix?!? Did you do that?
Today I got
My Custom Title
My Custom Title
On my 9's I've got 255/40/17 with no issues (besides some slight rub on hard right turns, or normal turns with 4 people in car). If I had a turbo car I'd love to go much wider
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
