VDO water temperature gauge sender
I'm not feeling the love for the in dash water temp gauge. Mine seems to read high and I would rather not send it off for recalibration. From some searching it seems the factory temp sender might be a standard VDO 10-180 ohm sender. Can anyone confirm if this is the case?
http://www.clarks-garage.com/shop-ma...19.htm#coolant
I was planning on fitting a VDO gauge and just wiring it to the factory sender. Would probably keep the in dash gauge connected to the same sender also. Anyone done this? Probably looking at a gauge like this.
http://www.egauges.com/vdo_ind.asp?T...ion&PN=310-105
