Clutch Hydraulic Hose Bracket
I have a new clutch line arriving soon and I wanted to get the old one out.
Can't get to this bolt on the line-holding bracket:
![](http://www.944time.com/porsche/2011images/2011-clutch-slave-line-bracket.jpg)
I can't even tell if it is 7mm or 8mm. In any case, a socket doesn't have clearance to get onto the bolt head.
Anyone have any luck undoing this?
Got the bolt off. It is an 8mm nut.
I removed the starter power wire clamp (10mm) and had enough clearance to get in there. Just barely.
The clamp seems to be built into the bracket. It does not come off.
