How quick does a rod bearing fail?
#34
Even cheaper here.
Has anyone actually run these bearings and can verify that they fit and that they are no worse than stock? I'm looking for a set of rod bearings right now![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
#36
#37
good read here
http://www.aa1car.com/library/ar797.htm
Scroll down to "bearing material". Keep in mind, Federal Mogul manufactures our Glyco bearings.
#39
Here you will find detailed informations on Clevite engine bearings. http://mahleclevite.com/publications/EB-10-07.pdf. Read the technical part and about High Performance/Race Applications. The Clevite Trimetal rod bearings are far superior to the Aluminium Bimetal Glyco factory bearings. Never ever use alumium bearings in a high performance application. Use Clevite bearings of the TM77 material for high performance. As said by Michael Mount in post #9 you can grind down the rod journal to Chevy 327 size (2.000") and use NASCAR type performance rod bearings (CB-1271P). Custom made rods are required. Doing some research I found the Toyota V6 NASCAR type rod bearing CB-1628H (CB-1628HX for more oil clearence). This top of the line bearing will fit right in using the factory crank and rods for the Porsche 928, 944 and 968. The 1628 bearing is smaller in width (.7600") compared to the factory Glyco bearing (.9449"). According to all experts I have consulted this should not be an issue. Remember a Toyota V6 high performance turbo engine do put out way over 150HP per cylinder. On 928 stroker engines up to 7,4L the most common setup is using Chevy SB H-profile rods and Clevite CB-663HN (.7920" wide) NASCAR type rod bearings. I have been in this game for more than 45 years and experienced many rod bearing failures. In the old days, for certain applications, we used diesel engine bearings which usually are harder and it worked. Somebody said hard bearing material will wear down the journals which I do not believe. Maybe somebody like to install racing bearings in a street car and drive it for 300.000 miles and take it apart and see if we can measure any wear.
Ake
PS The Chevy CB-663HN bearings do cost even less, I have paid $ 7.49 ea (per rod).
Ake
#41
I'm finding this discussion very informative. Keep it up.
#42
#44
I am intrigued by the windage ports Porsche introduced with the larger blocks 2.7, 3L, and I have been reading up on it. I'm starting to believe this might be the most overlooked detail in all the discussions on the #2 failures.
![](http://www.lindseyracing.com/HPTpics/HPTWP.jpg)
There is an article on it in the Lindsey newsletter [URL="http://www.lindseyracing.com/hptalk/0808.htm"]here[/URL (scroll down, or search for "Shop Talk")
The thought is that a windage port cut above the bearing between cylinders 1-2 and 3-4 will allow the air trapped below the piston to move freely from cylinder to cylinder without blowing past the crank and frothing up the oil. I'm wondering if it could not be blowing the oil out of the gap between the sides of the rods and the sides of the journals, possibly pulling the oil film out of the bearings in the process. Perhaps the pressure builds up the highest in cylinder 2? The port between cylinders 1-2 looks bigger than the one between cylinders 2-3 .
#45
Great stuff guys.
Thx
Thx
