Help with DME temp sensor test
'88 944 N/A
Trying to do a DME temp test as per clarks garage. The way I'm reading it you disconnect the long narrow wire connector at the DME under the dash on the passenger side of the car and connect to terminal 13. The terminals aren't numbered. Which one is 13?
Found the diagram. Got a reading of 3.33 at the DME which according to clarks is good. Is that the same as testing at the fuel injection temp sensor on the engine. I tested at the sensor and got the same cold reading but read a thread where someone got a cold reading of 1.24 cold and .31 hot and was told that is normal. I haven't tested hot yet.
