Clear Side Markers & Turn Signals
I got my clear lenses from www.HookedOnCars.com they turned out great. I had a bit of a problem with my one turn signal, the original bulb would work but not the LED i switched the connector from positive to negative and it worked. The only other thing you have to watch out for is the plastic tab in the side marker that keeps the light inside, I snapped the one off by accident.
( The job was even easier with the front bumper removed, at the same time i drilled out my bumper shocks , Also I am repainting the front nose)
Here is a before and after shot
