S2 into 8v NA Wiring Help
I have the 14 pin comparison between the 944S2 and 8v NA but I need a little help. http://members.rennlist.com/tholyoak...wap_wiring.htm
The car does not have any of the factory fuse panel and the critical terminals on the 14pin connector are wired directly from the aftermarket dash for the v NA.
1) For the NA pin #1 provides power to the coil. I do not see a coil power spot for the 944S2.
2) For the 944S2 I see pin#14 is for the ground for the ignitor. Obviously I do not have an ignitor in the 8v NA. So....do I need the ignitor? I have one and the four wires are Black, Brown, Green and Green. Where do these four wires then connect?
Hope this makes sense
Thanks!
Thanks!
