Pin 19 DME
I am troubleshooting an issue where my 85 will start and then die after a second or two. The issue started after I had had the intake off replacing vacuum lines. It would run at first but poorly and the idle would bounce up and down now it will start for about 2 seconds and die. If i squirt stater fluid it runs for about 5-7 secs so I was thinking it was cutting the injectors.
Pulled the DME and pin 19 is burnt. Its apparently the ground for the DME so I believe my DME to be fried and thus be the cause of my issue.
What would cause this pin to get hot though? I dont want to get a new DME and run into the same problem. From what I can tell the grounds runs to the top of the bellhousing. I guess its possible I knocked the ground or something when I was replacing vacuum lines.
Is there anything else to look out for.
