Polk plate speakers- will these fit front and rear? Stock holes
I have Polk MM461p in front. Put them in with the tweeter on top and you should be fine. I have the part that the speaker grill attaches to acting as a spacer for them, but if I remember correctly, you don't really need to do that. Ohh, and I fit some 6.5s in the rear. I know my '89S2 already had a 6.5" opening cut back there, but I know that if you do a bit of cutting, you'll be able to fit 6.5s back there without a problem
you have an 86 like me.....unfortunately not until 87 did they make the rear holes with the removable plate which if you remove you can fit the 6.5's.....so for 86 and prior......drummel is required.
