944 Turbo power loss
Old 11-27-2011 | 09:36 PM
bowering's Avatar
bowering
3rd Gear
Default 944 Turbo power loss
Hi all,
I have a 1990 944 Turbo (952 model) that's just started having a very intermittent power loss. It'll suddenly lose power and drop to idle revs. This happens when it gets above 200O or so RPM, but doesn't always happen. It's a pain to drive at 2000 and below!
Any clues on what this might be?
In case it's relevant: It's also been idling a little rough for a while (and sometimes 'hunting' between 800 and 1000 RPM).
It had the clutch slave and master cylinders replaced a week ago (by the mechanic) and the power loss has happened since then.
Thanks, Gary
Old 11-27-2011 | 09:41 PM
ballysdad's Avatar
ballysdad
I would be looking for a vaccum leak based on the senerio. If it just started happening out of the blue I would look to the AFM. The trax on the afm may be getting deeper, it is possible to readjust them to a clean area.
Old 11-27-2011 | 10:18 PM
bowering's Avatar
bowering
3rd Gear
Thanks balysdad. I was thinking vac leak as well. Does seem worse when hot. Gary
Old 11-27-2011 | 11:22 PM
Paulyy's Avatar
Paulyy
Professional Hoon
952? Where you from mate?
check for vacuum leaks, original vacuum likes are known for popping off.
have a look at the flap in the AFM, it may be getting stuck.
Ask your mechanic what he did to replace the Clutch master cylinder.
Old 12-04-2011 | 09:14 PM
bowering's Avatar
bowering
3rd Gear
Update - the problem was a ruptured inlet manifold gasket. Thanks for all the suggestions. cheers, Gary
Quick Reply: 944 Turbo power loss
