flickering dash lights
Hi guys , its been doing it for a while , steadily getting worse.
I thought it was the voltage regulator as I was getting low readings of like 12 so I replaced that ( what a PITA ) which needed to happen as the old ones brushes were like 1/4" and 5/16" respectively. Anyway now my volts seem fine, im back up to 13.5
Is my alternator failing ? readings at battery with car running and all accessorys ON are like 13.29
Ground on battery is fine in fact all grounds on the car look fine as the car is super clean...
Any thoughts ?
Car is 1990 944 s2 cab with 92000 miles on clock
Any thoughts ?
