CV Joint Options
CV Joint Options
In need of a new axle. Thought it was going to let go on the interstate coming home from work last night. Backend was shaking; I could feel it coming through the shifter, but that's another story.
Both Oreilly and Autozone show the part on their websites, but when I called to order, both places said they no longer have stock of the part in their warehouses and that I must "return for repair." I don’t think it’s worth it considering some of the bad reviews of their axles by other posters.
Other options for complete axles include:
Napa ~$185 (reman)
944online ~ $140 (reman)
Pelican, Paragon, Performance Products >~ $200
My leading option is to buy CV rebuild kits from Allzim for $50 a piece. Saves me some money, get to learn a new skill and don’t have to send the axle out for repair. I’ve never done business with Allzim. What do other people think? Does anyone have experience with their CV kits?
Also, are there any other things that I should consider doing while I have the axles off? Would this be a good time to do transmission mounts or anything?
Thanks in advance,
-bp
Napa ~$185 (reman)
Thanks in advance,
-bp
Napa ~$185 (reman)
Thanks in advance,
-bp
Napa ~$185 (reman)
Thanks in advance,
-bp
I went the NAPA route w/in the last month or so, so far so good!
It can be kind a real mess, so what I do is install the axles dry and after they're installed I pull off the clip that keeps the lip of the rubber boot tight to the axle, inject a tube of axle grease with a food syringe under that lip into each CV joint, and then replace the clip with a tie-wrap.
I just installed 2 CV axles from NAPA, remove your old ones first, and turn them in as cores when you pick up new ones.. total for 2 axles, a tube of grease and 2 cans of brake cleaner was ~$160... there is a hefty core charge included in the listed $180 price online!
Is it worth it to replace bolts, spacers or the gaskets when I do the job too? What about transmission mounts? Can bad mounts lead to premature CV failure?
Thanks,
-bp
Wow. Maybe I should try to read... I am so used to prices without the core included. Napa does it the other way around. Thanks for pointing that out. This sounds like the best option for the money.
Thanks,
-bp
Thanks,
-bp
And yes a worn out trans mount can kill CVs.. to the extent that some folks have devised a brace bar for their trans, I have used both solid and semi solid mounts, and will be sticking to the semi solid mount from here on out on my 44s...
Perhaps on the bolts, cant hurt to have replacements on hand just in case one strips out..
Thanks,
-bp
The later cars use only one mount that holds the top of the trans. Most people will fill it with urethane, or get a semi solid mount from one of the vendors that makes one.
Just a quick endorsement for Allzim... I think you have already decided on the best choice for you. In other transactions (Powersteering related) they were great!
best of luck!
best of luck!
