WTB: 944 Passenger Front Frame Rail Cut from Firewall
My last race I had a pretty big impact (someone hit a mud puddle going off track which hit my windshield blinding me and as I was slowing down and pulling off the racing line that same racer spun across the track when coming back on and we hit.)
Damage is not too bad considering the impact however the front 12" of my frame rail needs to be replaced and the body shop needs a known good frame rail (not previously repaired) cut off from the firewall so they can use it to do the proper measurements and replace the damaged area.
I'm hoping someone has a damaged enough car that the shell is too far gone so that they'd be will to cut off the rail at the front. Please PM me. Thanks.
I could buy a whole shell so I could cut it out but the distance is too far right now
I did get a hold of A Part Above and using a previous hard luck award from the race (got it b/c of the damage) I get a discount on the part when John gets back from racing.
Actually depending on when you need it I could make you a good deal on the shell probably. I should be done stripping what I want/need from it by the end of the month. Sell it to you for scrap value at that point because that's what I was going to do with it even though I hate to see good quater pannels ect go to waste.
I'm not sure I need a whole shell nor want one in my garage - however there might be need locally here in KC for track car builds. I'll pass this onto a friend who builds track cars. Always good to have a shell lying around in case you wad up the racecar too badly.
