Rear defroster resistance????
So my rear defroster does not work.. All voltages are correct, relay and fuses are fine, and the hatch shocks are correct. I think the problem is too high a resistance through the heater elements on the hatch window... I get 30K ohms across the hatch defroster heater grid... Anyone know what the resistance should be? Is there fix that can be done?
Thanks for your response!
-CKKrause
-CKKrause
http://www.924.org/techsection/rear_defrost.htm
Try that out. Mine isn't working either and that's the first thing I'm doing tomorrow.
I took a look and since the resistance should be 7-8 ohms and I have 30K ohms, the grid is the problem.... Am I SOL???
