951 brakes under 15" phonedials ,myth confirmed !
Old 08-15-2011, 04:35 PM
Olli Snellman
Olli Snellman's Avatar
Old ET Phonies under '91 951 Cab must have been looking quite odd
Old 08-15-2011, 04:36 PM
catamax944
catamax944's Avatar
Originally Posted by V2Rocket_aka944
6mm is huge.. good to know..
if you get a chance, could you measure the inner diameter of your wheel?
i want to see if my 15" BBS will clear too
37cm at the rear then goes down to 35cm mid way and finaly 33cm where the hub meets the wheel (caliper doesn't go that far). I think if you have at least 35cm it should be fine.
Olli Snellman
Quote:
Friday i got my 951 brakes from member "sdstimson" that i would like to thank ,real great guy to deal with, all parts are perfect and i got them in a mind blowing 2 days ,from USA to Italy in 2 freakin' days.
Bergamo is quite close to Rome... It's funny when person located in Italy buys italian made stuff from USA
I just test fitted a 951S front caliber under E30 BMW's 15" BBS wheels. Fit like a glove. I wanted to use 951 S front caliper with 16" new ET Phonies, let's see how they fit, or do i had to make some modifications
money talks...
Rock:
Theres a myth? I was rocking early offset phonies on a 1991 944T Cabriolet all the time. In fact my car got wrecked with one on the front (not the cause of the wreck). I put more phone dials on it from an 86 N/a and drove it home after all of the tires got ripped off.
Since you or anyone else may not have mentioned this to us before i consider it a myth.
Old 08-15-2011, 04:45 PM
Rock
Lazer Beam Shooter
Rock's Avatar
It did look very odd. They also sat out a lot because of the offset, and it looked strange.
Old 08-15-2011, 05:20 PM
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
Nice! Good to know, I'll pass it on -
Old 08-15-2011, 05:23 PM
86 951 Driver
86 951 Driver's Avatar
As far as I know no 951 came with 15 inch wheels. Are you sure you mean 951 part number on a phonedial.
Old 08-15-2011, 06:27 PM
951Saga
951Saga's Avatar
According to this site, 944 Racing, there is a 15x7 et23 part number 951 362 104 00.
Old 08-15-2011, 06:31 PM
catamax944
catamax944's Avatar
I think they were used on very early turbo prototypes.I recal seeing a picture of a 84-85 turbo racecar with these wheels.
Maybe after that they put them on the 85-86 944's without changing the moulds.
Old 01-26-2013, 03:18 PM
Dutch944
Dutch944's Avatar
So guys, just for a confirmation here: Will the standard early ET (ET23) 15" phonedials fit on a late offset car (ET56) with 944 turbo brakes? As i'm ready to fit my new brakes and i still want to drive the trackdays on "cheap" tyres..!
Old 01-26-2013, 04:10 PM
North Coast Cab
North Coast Cab's Avatar
951 or 944 rotors?
Old 01-26-2013, 04:19 PM
catamax944
catamax944's Avatar
They will fit over the brakes but i don't think they will fit the late offset suspension unless you dial in a lot of camber
Rock seems to have done it but i don't know what his setup was
Originally Posted by North Coast Cab
951 or 944 rotors?
'86 951 spindles/hubs/rotors/calipers
Old 01-26-2013, 06:59 PM
Dutch944
Dutch944's Avatar
Well.. They are on my car at this very moment and fit perfectly! And yes i'm driving plenty camber at the moment (track-mode)
But i as i'm still driving the N/A brakes they'll fit the brakes easily. So this is actually very good news.. Saves me a lot of money!
Old 01-27-2013, 11:12 AM
car_slave
car_slave's Avatar
The early offset will fit, it's the late that won't.
Quick Reply: 951 brakes under 15" phonedials ,myth confirmed !
