Removing parking brake cable from rear hub?
Hello,
I am swapping trailing arms from steel to aluminum.
Can anyone tell me the procedure for removing the parking brake cable from the hub on steel arms and on aluminum arms?
Thanks,
Alex
Thanks,
Alex
I removed the brake rotors on the early steel arms. The hub with the studs pressed in is very much in the way of the e brake assembly. Is there a way around this?
