Stuck on Starting Issue
Old 08-07-2011, 02:00 PM
Tom M'Guinn
Tom M'Guinn's Avatar
Originally Posted by ZR8ED
A potentiometer inline with the temp sensor wire, is an old "trick" to fool the ecu that the engine is still cold, and give it an extra boost of fuel. It doesn't really work on a stock engine, but it does have some effect on engines with very mild mods that the ecu is not programed for. It is very old school.
Good point. Worth testing the sensor before ordering a new one. Either way, remove the potentiometer.
Old 08-07-2011, 11:05 PM
Dogberri
Dogberri's Avatar
so pretty much all its doing is hurting my gas milage?
Old 08-08-2011, 06:53 AM
Legoland951
Legoland951's Avatar
So what you are saying is that you fixed the problem by removing the potentiometer and everything works fine now? I fail to see how the block temp sensor can keep the car from revving.
Old 08-08-2011, 03:17 PM
Dogberri
Dogberri's Avatar
I soldered the broken tab back on to the potentiometer. im not sure why it affected the performance the way it did. these engine management systems are beyond me.
Quick Reply: Stuck on Starting Issue
