bad mpg
bad mpg
my car seems to be using lots of gas not sure what the mpg is but it doesn't look good. the car passes aircare so it can't be running too bad.
I have replaced the air filter, wires. replaced a the cap and rotor like 4 years ago and plugs 2 years ago. i'm going ot replace the plugs this weekend (NGK vpowers).
not sure if I should replace my cap and rotor the probably have 30k kms on them.
my o2 sensor is probably stock I was thinking about replacing that with a universal one soon.
other than that what else should I check. I was told once that my car smells like it is running rich.
Proprietoristicly Refined
Clean (or replace) the injectors and replace the seals either DIY or a pro like www.witchhunter.com
Do you use the small throttle cam?
DME engine temp sensor could be bad. Clarks has a test. Could be staying in rich mode.
Put a locking gas cap on
GL
John
GL
John
