Rec a NYC area shop to restore a saratoga top?
This is a little esoteric but does anyone have a good glass shop in the NYC area that they would recommend?
I've got a saratoga top that needs major restoration before it's usable (seals, metal framing, etc). My guess is that an auto glass shop could do the job, and perhaps reseal my hatch too.
Any recommendations?
Which one do you have - Bronze tint/frameless, or Grey tint/black framed? Manual or power? I have the late grey tint/black framed power top version.
If you have my version, you should be able to reseal the frame to the glass yourself if it is separating. You should also be able to sand/scuff, clean the frame with a little lacquer thinner and repaint it before you seal it if necessary.
How bad is the top? How bad is the seal? My original seal is still good, if you have to replace, you will have to use two small VW seals or find a way to make your own. Porsche does not have a replacement and you cannot get original seals anymore as Saratoga is long out of business.
You will be hard pressed to find a glass shop who will be willing to take on the job of resealing your hatch. Do a search here and read up on that portion.
Grey tint, black framed, power.
The prior owner of the top tried to do a repair with what looks like jb weld or something. It's pretty ugly.
The seal I knew about and and I have the vw part number for the seal. Surprisingly expensive for a VW part...
For what it's worth, my hatch is just starting to delaminate/unseal, maybe about a four inch long section. Pissing me off to no end. I think I am going to silicone it and see what happens with the rest of the hatch over time.
